Provide the ability for administrator or user to create and save a configuration filter that can be used during Checkout/Add To Workspace.
This saved configuration filter could then optionally be set via the existing Preferences:
Preferences: Current Values: Additional Value:
Set Configuration for Add To Workspace Default/Latest/As_Stored <User Defined>
Set Configuration for Check Out Default/Latest/As_Stored <User Defined>
Background:
We have a need for Latest Released data (or In Work if no version has been Released). By giving the option of saving the configuration filter, it would allow our needs to be met and also allow for other customers to meet their own needs.
There are also some default configuration filters (Latest/Baseline/Promotion Request/Baseline), but these too do not provide Latest Released. Configuration filters can currently be created each time (8 clicks?), but not stored for use again in the Checkout/Add To Workspace dialog. From the structure page on a checked in object, there IS the option to Save a configuration filter, but these do not show up during Add to Workspace or Checkout, also these cannot be set via the Preferences shown above.
