When using NX with Windchill 10.1 It would be very helpful to have a Save and Upload in NX (that saves the object and uploads it to server side workspace).
working with Windchill 10.0 a command in NX was available Save to Workspace that actually did this.
In Windchill 10.1 the Save to Workspace was 'enhanced' meaning that Save to Workspace was only available for new objects only.
Having a Save and Upload available in NX would be very helpful as it enable engineers to decide to do from NX a Save (save only) or Save and Upload (which save and uploads)
Having this Save and Upload command in NX provides a much more effificient process as the engineer does not need to save from NX and than upload from the workspace.
The command in NX preferrably should be named Save an Upload as that is what is does ...
