Be able to use several classification attributes to build criterias in searches to narrow down the result. Example using classifiation attributes: "Project Reference = W60-2952" OR "Function Group = 120" .
In the same way as for ordinary attribut criterias, see picture.
As-Is Search work Project Reference "W60-2743" AND Project Reference "W60-2983" and so on,
you will not hit anything.
To-Be Search work Project Reference "W60-2743" AND/OR Project Reference "W60-2983" and so on,
