With Creo Elements/Direct Model Manager it is possible to search for the loading type of a model in CED Modeling or to filter in the structure list. A distinction can be made between "Fully Loaded", "Partially Loaded" or "Lightweight Loaded Models" (see picture).
With the Workgroup Manager for CED Modeling, the load type can be changed, but the status of the loaded assemblies cannot be searched or filtered.
Many CED customers often use containers in assemblies, e.g. to display construction variants and add-on parts.
With the new function not to load containers immediately when loading a model from Windchill, there is now no way to display all of the partially loaded objects in the construction. This makes the work more difficult, since from version CED Modeling 20.3.x on all containers have to be fully loaded for moving assemblies in order to avoid recursive references.
It is therefore imperative to enable a search or filter for "Fully Loaded" or "Partailly Loaded".
See Case https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=15991554
