This applies to Windchill PDMLink 10.x.
Symptom: Search for an object. Within the search results, right-click on that object and choose Revise. Once the action is complete and the object has been revised, the search results are not updated. Thus, if you right-click on that same object again, you are performing an action on the previous revision (not the latest).
I would ask that the search results be refreshed after performing a revise action, similar to how the search results are refreshed after deleting objects (i.e. the deleted objects are removed from the results).
Note: I have engaged Tech Support regarding this and they have stated that this is working to spec for all versions. They have asked for a Product Idea to be submitted.
