Currently we have our Physical Products separated in to Products that share the same name (all data for the MB2 chassis is in the MB2 product). We have users that will keyword search for MB2 to find layouts (our layouts are named MB2-164-.......). What the system returns is all documents that have MB2 somewhere in the file, which is expected, what is not expected is that the system also returns ALL objects that are in that Product of the same name. It will return a CAD file that is called TEST.asm, even though the only link to MB2 is that it's in the product. My idea is there should be a way to disable this type of functionality via a preference. Most of our Products contain tens of thousands of objects and it makes the search useless.
