Select IBAs when customizing the search results table view
In reference to Document CS63168.  We should be able to select the IBAs to display with customizing the search results table view.  If only one type (e.g. CAD Document) is selected for a search, the IBA's are available to display in a customized search results table.  However, if more than one type is selected (e.g. CAD Document, Document), IBA's are not available.
It seems that the IBAs from each of the selected types could be made available to select to display in a customized search results table.
7 Comments
gmehta
I personally think as long as a common (even if its custom) attribute is available then we should be able to add it to the view.
BenPerry
Michael Schumacher‌‌ & Gord Mehta‌,
I'm not sure if this will solve your use case, but in Windchill 11.0, if an IBA contains the value that you searched for, that IBA column indeed will be automatically added to the search results table.
For example, if you search for "steel", and you have some WTParts, EPMDocs, and WTDocs that all have "steel" as a value of an IBA, then those columns will be shown ad-hoc.
Does that make sense?  Does that help solve your idea?  Or are there other attributes you'd like to see in the table view that you didn't search for?  Can you give example?
CaitlinWheeless
1-Newbie
Hi Gord - You might want to check out the discussion under this product idea: Allow all fields in Windchill search
gmehta
Thanks a lot. This is exactly what we are looking for.
We will probably upgrade to WC 11 in late 2017 or early 2018.
CaitlinWheeless
1-Newbie
Vikram Sinha‌ - Another that can be marked current functionality
Vikram_Sinha
Done (marked as current functionality)
PTCModerator
Emeritus
Status changed to: Archived
