When you collect in "Save as" items which are collapsed with the SHIFT Key as you do in Structure Browser all sub items will be marked as well.
If you use STRG Key to mark only the dedicated item is selected. So I think it's designed by WT Development.
That means much effort to mark all elements in a big structure.
The idea is that e.g. pressing STRG+SHIFT collects all the items WITHOUT sub items.
