Request is to have a pop-up message requesting to refresh the page as soons as the connection with the server is lost or an indicator somewhere (green light/ red light for exemple ) to check if the connection is still available.
Because the lost of connection with the server happen quite often (period of non-activity for example) and users still continue to work and get error messages or strange behavior.
