With the major UI changes from Windchill 9.1 to 10.0/10.1, there were some great improvments in UI capabilities. Unfortunately, there were also a few changes that IMHO are a step back from the capabilities in 9.1.
Set Up participants tables is one of them.
The worst case scenario at my company is the set up participants node for users in our Critical Design Review (CDR) Process. This node requires our Systems Engineer to select 5 users in seperate groups. In 9.1, this required 5 mouse clicks. (Actual user names blocked out)
In 10.0/10.1, this same activity requires 21 mouse clicks. Seletion of Set Up Participants tab and then 5 clicks per role. Example of first role with 6 clicks:
Each subsequent role assignment requires 5 additional clicks. If it must be a separate tab for Set Up Participants, that is not a big deal. But why can't that tab have a similar table layout to what was in 9.1.
Jason Knighten
