Set folder for Dynamic Documents created using EPMPostPublishDelegate to same folder as source EPMDocument
I have setup a publish rule using the EPMPostPublishDelegate function to create a Dynamic Document of the system created viewable so that it can be used as the input for Arbortext IsoDraw CADprocess or Creo Illustrate.
The problem is that the Dynamic Document gets created at the base folder of the Product/Library.  The EPMPostPublishDelegate allows you to specify a particular container and/or folder for the Dynamic Document to be created in, but what would be best is if the Dynamic Document gets created in the same folder as the orginal source EPMDocument.
3 Comments
mschulze
Yes Allen, this is realy annoying!
AllanThompson
Hi Matthias.  This has been implemented in Windchill now.  In 10.2 if you don't set a folder option in the XML file then the Dynamic Document gets created in the same folder as the source EPM.
Thanks for voting for my idea.  I guess someone else thought it was useful, even if it wasn't my idea that got it put in, seeing as it's still listed as open.
PTCModerator
Emeritus
Status changed to: Archived
