Set revision while doing save as
Can PTC include the feature to set the revision an object while performing Save-As operation?
6 Comments
BenLoosli
23-Emerald II
What object type are you asking about, documents or EPMdocuments (CAD files)?
There is a huge difference in the planning and coding between the 2 while doing a SaveAs operation.
Also, EPMdocuments could be parts, assemblies or drawings and each has different need?
Some additional information on this request would be appreciated.
admin_sp
3-Visitor
Our current requirement is for the WTPart and the WTDocument.
lhoogeveen
Is there any functionality to set the Revision today (outside of the save as)?
BenLoosli
23-Emerald II
I set the revision on documents from the New Document screen when a document is created.
I have a procedure for setting the revision for new CAD files and WTparts.
I have NOT tried a SaveAs in Windchill or Creo, yet.
lhoogeveen
@BenLoosli Could you share the steps on how to set the Windchill Revision manually for new objects?
BenLoosli
23-Emerald II
Multiple parts to accomplish this.
Preference changes
Set Preferences at the Organizatrion level for all users.
  1. Selecting a revision out of Sequence
    1. Expand ‘Revise’
      1. Change ‘Allow Override on Insert’ to Yes
        1. will display insert actions and allow user to specify a revision label.
      2. Change ‘Allow Override on Revise’ to Yes
        1. will allow user to specify a revision label when doing a revise.
Layout changes
Add the system Version to your layout(s)
If you want to just enter the value, that is all that is needed
If you want a drop down, Select the Version attribute in the layout page and right-click for Group Attribute Properties. At the bottom is Data Utility ID, add revisionPicker for the value.
