Set the default orientation in PrinterConfig.xml for batch print.
Problem discribed in the case C11883286.
The idea is to set the default orientation for each new printer in PrinterConfig.xml. Currently, according to the response in the case, orientation in batch print, sets from the template in Creo. But this functionality is not possible to correctly print A0 and A1 drawings on one the same printer.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
