At the moment, the auto connection in Destop Integration is working when the application, e.g. Outlook is closed and reopened after connecting to the Windchill server, but not after a shut down of the PC.Then the users have to choose the active server manually and connect again.
To set a a default active server in DTI would solve the problem and after starting the MS Office application it would automatically try to connect to the default windchill server.
