Setting a default active server in DTI
At the moment, the auto connection in Destop Integration is working when the application, e.g. Outlook is closed and reopened after connecting to the Windchill server, but not after a shut down of the PC.Then the users have to choose the active server manually and connect again.
To set a a default active server in DTI would solve the problem and after starting the MS Office application it would automatically try to connect to the default windchill server.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
