Setting a default string value MBA / IBA attributes with OIR
Today, we can't apply default string value on MBA and IBA Date/String/... attributes with OIR because according to ptc, it's not compatible with GetServerPreGeneratedValue mode. (case 13297476)
3 Comments
Aquamarine
Setting a default string value by OIR
<AttrValue id="ptsERP" algorithm="wt.rule.algorithm.StringConstant">
<Arg>12345</Arg>
</AttrValue>
How to make string soft attribute immutable with a default value in Windchill
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS115839
Yes but our need is to display this default value with GetServerPreGeneratedValue mode and that doesn't work. Have you test this test case?
Aquamarine
1. Add the following Object Initialization Rule to your type (wt.part.WTPart)
<Arg>12345</Arg>
</AttrValue>
<AttrConstraint id="ptsERP" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
   <Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
</AttrConstraint>
2. Edit the following  %WT_HOME%\codebase\com\ptc\core\rule\server\delegate\init\RuleConfigurableTypeAttribute.properties.xconf:
   <Property name="wt.part.WTPart" default="number,name,ptsERP,lifeCycle,lifeCycle.id,teamTemplate,teamTemplate.id,folder.id,organization.id"/>
3. Run "xconfmanager -pF" in Windchill Shell and restart Windchill
