During a promotion, there is a comment field where someone can write a comment related to why this item got promoted. This 'could' be similar to a revision table in a drawing where he would write "changed 1.3" dia hole to 1.4". We would like to see this attribute available for the history tab. The history and maturity tables both show the promotion name, but they don't show the comments from this promotion. We would like to try to remove the revision table from our drawings altogether, and the solution was going to be using the comments field and a custom view in the history table. I think this would be a great idea, without needing to create a custom report.
