Show described docs in Affected objects
Ave Caesar,
when some document having multiple use in MPMLink (like picture is related to more than one operation in process plan) we also need to see it via Affected Objects in Change Task.
Let's say I have dozens of pictures and going to replace them at some operation. Nowadays before creating a revision I have to use report or manually check every single document from Relation Explorer to get info if document is used only 1x or not. That is very uncomfortable and wasting of time.
We would like to see it in Affected Objects to get quick info. Point is to have detailed knowledge before revised. Often users forget to check all relations and revising docs with multiple use in wrong way. Then document is changed everywhere even they didn't want to. This could provide visible info and reduce all mistakes:
1 Comment
olivierlp
Community Manager
Status changed to: Archived
