The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Show language code in WVS Job Monitor when publishing
If many languages are published, for example to PDFs using the Publishing Engine, at the same time it is not possible to identify which publishing job is related to which language in the WVS Job Monitor.
I would be nice to have the language code in the Job Summary Part of the WVS Job Monitor alternatively (not preferred) it could be possible to add some language in formation in the Job details section.
3 Comments
mschulze
What would be the benefit, if you know the language in the job monitor? What is your use case?
MNerman
3-Visitor
When you publish a book to PDF in SIM using the Publishing engine and you publish more than one language at a time and one for some reason fail it would be very good to see, in the WVS Monitor which failed.
This is maybe not super relevant if you have one or two but if you have, like in our customers case have 24 languages it is not super easy to identify which publication failed. Then it would be much easier to see that information (if SIM Is installed) which language is published.
olivierlp
Community Manager
Status changed to: Archived
