When we analyse the usage of a part in a BOM thanks to the "Where Used" tab, the analysis is not complete as it does not report its alternates (ALT) nor its substitutes (SUB).
The table should show them as well as their parent usage links so the user can study all of the use cases of a part.
Also, another column in this table, indicating from which kind of relation the parent originates from (direct parent, alternate, substitute, etc.), should be added so the user can know directly why they appear in the table.
