Show second scroll bar fully when two scroll bars are shown on the screen
Symptoms
The inner scroll bar is not shown fully when two scroll bars are shown on the screen.
Workspace Save As:
Detailed view from above:
Tested with Creo Elements/Pro 5.0 M190 and Internet Explorer 8.
This simple bug needs extra time each time a user run into that situation:
  • Save As of ASM
  • Switch to "Required" dependents
The issue is reported to show up in other situations/dialogs as well.
See also: PTC C11536262
3 Comments
_Marc_
9-Granite
This issue is fixed at least since Windchill 10.2 M020, Internet Explorer 10, Creo Elements/Pro 5.0 M230.
The idea can be closed.
slapha
Creo Parametric 2. Windchill 10.2 M030, IE 11.
It still happens. You can adjust the length of the inner window so you only get one scroll bar, but it should be intelligent enough to resize automatically based on window size.
Might be implemented/better in Windchill 11.
PTCModerator
Emeritus
Status changed to: Archived
