The solution installler should be able to insert the downloaded zip-Files directly into the staging area without the need of unpacking the files before.include
Also the name of the Zip File should the full information like
PTC Windchill 10.2 M020 - Index Search MED-ASDSAD-CD-102_M020.zip
