When a Part is replaced by another one in eBOM using the action "Replace", it is not easy in mBOM to retrieve the equivalent part/occurrence of the original Part, especially when mBOM is widely restructured compared to eBOM. The reconciliation assistant is not well adapted.
Similarly to the action “Select Equivalent Parts on the Other Side”, there should be an action to retrieve the equivalent of the original Part.
