Sorting on narrow columns (modified status, obsolete, ...) is not as straightforward as it was in PDMLink9 as the text of the column is not selectable.
We need to go through the menus.
The sort action on these columns is often used.
Could the columns be defined with a minimum size ?
Or, Right click on the column could access the menu and left click to sort directly.
