The prompts or lack of is not standard in Windchill. Example is when adding a link (Describe By reference etc) when in a WTPart to a WTDoc it will prompt that you are checking out the WTPart. However if in a WTDoc and you add a link to the WTPart, it automatically checks out, checks in and iterate with no prompt. It would be awesome if the prompts were standardized so if it prompts when a action is taking place, it will regardless of where it is done from.
