The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Supplier Manager should be able to add/remove Manufacturer Part without Modify rights on WTPart
Supplier Manager should be able to add/remove Manufacturer Part without Modify rights on WTPart.
4 Comments
DonSenchuk
6-Contributor
By definition that is modifying the WTPart. It's removing the reference between the two. References between the two files is what the WTPart does.
SvenVanDroogenb
7-Bedrock
Maybe, but it isn't logic...  The reference should be stored in the Manufacturer Part.  A Manufacturer Part can be added/removed/changed when a WTPart is already released.  Adding second source, changing sourcing status,... has no impact on WTPart.
DonSenchuk
6-Contributor
PTC's philosophy is that the WTPart is the part, including information about the manufacturer part. This isn't saying your idea is bad, but rather it would be a reversal of PTC's WTPart methodology.
olivierlp
Community Manager
Status changed to: Archived
