The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Supplier Part Generate Request Form - is not intuitive
THe supplier Part Request form uses the last Reporting Class section that was opened instead of what the user actually selected.  None of the Reporting Class sections should have default values selected.  This would require that the user select the desired selection and only those would be sent to the supplier.   A curious user may select different Report Class just to see what was available and is therefore sending data in that section to the supplier unknowingly.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
