Support Cascading Attributes for edit in the Structure tree
We tested with the colleagues in OOTB ( 11.1 M020) the behave of two cascading attributes in structure view .
The structure edit mode is not working. For example :
 Both attributes we created are used in global enumeration value. If there is only one attribute than the drop down menu in the structure table view is editable. But when there are two cascading attributes connected with a rule the structure view can not be edited. The Idea here is: Possibility to support the cascading attributes for editing in the structure tree!
Please refer to the screen shots for more information.
5 Comments
Pearl
It would also be cool, if we could drive attributes across types. E.g. If the WTPart is a component, then you can choose different attribute values on the usage link.
Visitor
Forgive me if I'm wrong, but I think my organization is experiencing a similar issue.  We have run into trouble editing attributes for documents and CAD files when they have cascading values.  Any attribute included in a cascading rule isn't editable.  Our employees want to use cascading values because it makes lists shorter but they also rely on the ability to edit attributes for multiple documents/CAD files.  If the attribute has cascading rules, they are unable to edit it in this manner.  The idea of cascading attributes is great but so far we have been unable to use it because it has limited other functionality that people rely on.
Peridot
@zmayo Some notes
1) CAD Documents are not yet supported
2) Parts, Documents and Changes are supported.  Support for multiple create Wizards (Parts and Documents) was added Windchill 11.1 M010.  I'm attaching a video example with Parts.
(view in My Videos)
Aquamarine
Hello Jeff,
The video is nice, but this is still for new parts.
If someone wants to change the attribute the easy way is to use the structure.
So I vote for this idea.
Peridot
@HelesicPetr  That is correct.  That is a roadmap item.  The video above was in response to @zmayo  question about multi-create/multi-edit for Part and Document UIs
