Many customers need to define different change proposals and even build prototypes before they can decide what to implement in production. The data generated in the change proposal shall not be mixed up with current data. A sandbox area is needed. When a Change Proposal is accepted, it shall be possible to add the data to a ECN task, because most of the change is already done. Same use case is valid for Concept design. Please see attached ppt.
