Support SLDDRT files for SolidWorks templates.
The SLDDRT template format is used by SolidWorks as the format for a new blank sheet of paper.  For instance, when our users add new sheets to a drawing they will select the SLDDRT format for the basic page layout.
Currently Windchill recognizes and supports the use of the PRTDOT, ASMDOT, and DRWDOT, primarily (I imagine) because these can be assigned as the default templates for new parts, assemblies, and drawings.  Can we not also have Windchill recognize the SLDDRT as a SolidWorks file so it can be added to a workspace and used/managed in the same manner?
5 Comments
temmett-bec
3-Visitor
Would be useful to parallel functionality in Creo Parametric for organizations with both CAD applications to have consistency in their processes.
PTCModerator
Emeritus
Nick_A1
Drawing templates is used for new drawings. Sheet format is updating existing drawings to new changes. Both are required to support SolidWorks in the Windchill environment.
MS_3216205
2-Guest
This would be an enhancement that I feel is beneficial as users will no longer have to maintain the sheet format outside of the Windchill system allowing for integration at multiple facility sites access to the same information in one location.
kbeach-2
@PTCModerator any updates on this topic?  In addition to the SLDDRT files mentioned above, additional file types are needed.  BOM Tables (SLDBOMTBT), Weldment Cut Lists (SLDWLDTBT), etc.  Our organization is a dual-CAD environment that leverages outside contractors for CAD design.  We are leveraging Windchill ExtraNet to work with said contractors but are limited in our capabilities since Windchill doesn't recognize these additional critical file types.
