Support asking quantities when configuring a BOM with Option&Variant
When configuring a BOM with the option filter (Option&Variant), Winchill should allow user to give expected quantities. This capability should be proposed only for some options (Option Manager decision).
Example:
Option:
Battery:
□ Normal                   Qty: ____
□ High Capacity          Qty: ____
3 Comments
kpritchard
Why not do this as Option of Battery Quantity with Choices as the numbers of batteries for which there are available design solutions (or at least a willingness to create design solutions) for each Choice (Normal and High Capacity) in the Capacity Option.
JeffZemsky
Florent,
You have a few paths available today -
1 - Place Expressions on occurrences and have a choice for the number.  Assign the choice to turn on/off the number of occurrences you would like
2 - Advanced Logic (in PSE) will support a variable quantity and can be mixed with Options and Variants Logic to support this need
olivierlp
Community Manager
Status changed to: Archived
