Today, in Windchill 12 it is only possible to do a BOM transfer to CED Annotation if a assembly/part have a owner association to their part. If there are objects linked with image association the error "Picked geometry does not correspond to selected BOM component" is shown often.
For future versions it should be possible to use also objects with image-links for the correct representation of the drawing BOM in CED Modeling/Annotation.
See https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=16481489
