Support creation of publish jobs from a generated list
When a set of objects needs to be republished, a list can often be generated using SQL queries or other methods that identify the object's Name, Number, Version and Iteration, but there is no supported method to upload this to WVS for processing (that I can find). The available republishing tools are not granular enough to limit themselves to a known data set and would unnecessarily overload the workers.
3 Comments
Emerald I
This can be done today using PublishEPMDocWithCSVFile from this article: https://www.ptc.com/en/support/article?n=CS211115
Note:  You do not have to install all of the other custom publish jobs mentioned at the top of the article in order to use this tool from the command line.
Visitor
Thanks TomU - that looks like a good solution. I will try it and respond with any feedback.
Visitor
...the only part missing is the support.
