When a set of objects needs to be republished, a list can often be generated using SQL queries or other methods that identify the object's Name, Number, Version and Iteration, but there is no supported method to upload this to WVS for processing (that I can find). The available republishing tools are not granular enough to limit themselves to a known data set and would unnecessarily overload the workers.
