Support for changing label names for Modeled attributes in PLM
0 Kudos
I'm posting this on behalf of Krueger International.
Description:
Customize columns in the Change Notices Table view. Missing attributes can be selected for a change notice when customizing the views. Although the modeled attributes when their labelname is changed, do not reflect the names correctly in the customized view.
Using Type And Attribute Management, edit the base "Change Notice" type
Change the Display Name of the "My Need Date" attribute  to "Launch Date"
Save your work
Go to Changes > Change Notices
Using "Customize View", create a new view as follows
Use any name you like
Choose only "Change Notice" as the Object Type
Use no Filters
When you get to the "Set Column Display" portion of the dialog, note that the
"Available Columns" and the "Selected Columns" lists will not show the "Launch Date" attribute (the new name)
They will list the "Need Date" attribute (using the old Display Name)
1 Comment
olivierlp
Community Manager
Status changed to: Archived
