A common requirement we are facing is the need of two different revision schemes. A major revision describing a larger change, while a minor change is a cosmetic change (misspelling, move a view on the drawing etc.). When a new revision is created and released, lot of work is generated downstream with distribution to suppliers and manufacturing. With two different revision labels, the customer can decide to only distribute major revisions.
Even if the can classify the change in the CM process, the final result is a new revision.
Have PTC any plans to support major/minor revisions?
BR
Per
