Support setting Deadlines from within PBO's such as Change Tasks and Change Notices
Ideally there would be a way to connect the deadline of a Workflow Task to the Need Date of the Primary Business Object (Change Objects).  Since it would be a challenge to come up with a one size fits all solution providing the building blocks through a customer visible API would be extremely useful.  At a bare minimum, an API to set a Workflow Task Deadline based on a PBO Attribute (both modelled and IBA) would add huge value.  Better yet, having the ability to incorporate a listener that updates the WF Task Deadline if/when Need Date changes would allow for dynamic management of work associated to Change Objects.
3 Comments
HelesicPetr
It would be greate also for wt.maturity.PromotionNotice.
In many cases the static deadline which could be set on a task in workflow as number of days, hours... is not enough.
Every task should be dynamicaly set by needs of requester.
Now days there is only manual posibility to set it from task window in action menu by Edit Deadline.
Best Regards.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
