1. We need configurable table Displays for all Tables. e.g. "Checkout on the Fly " in Creo Parametric does not have a configurable table display.
What if I want to show Folders and CAD Drawings only? Currently the filter on Drawings would filter out the Folders as well as they are no drawings ...
In a CAD centric setup all the predefined displays forWTParts etc are worthless for the users - why can't we simply remove them?
. A Group Key user should be able to define a table display and to share it within his group. It doesn't make sense that each user has to define the Display again. What about defining table displays on context level? |
The users would love it to see what they want to see. We would achieve this by adding configurable table displays to all tables. With having conjunctions for filters in Table displays we would be able to display e.g. .only Drawings AND Folders (at the moment the filter "only drawing" would wipe out all folders and the second filter for "only Folders" would wipe out all drawings - so you see nothing). In many companies only a portion of Windchill is in use - so having all possible necessary system Table displays in the list is confusing the users - with having the option to hide them we would have a much easier to handle UI. The Predefined Colum width is essential to display as much information as possible on the screen without the need to scroll and page - This is a simple reduction of clicks and picks for the user - Engineers love to see all on one page to compare it and to get an overview. |
