In Windchill 8 for every .properties file a .annotated file was generated which showed from which xconf file the property was derived.
This funcionality is missing in PDMLink 10 -- It would be great to be able to generate those files for PDMLink 10 as well as this is more convenient than using the xconfmanager -d option for every property.
