Thier should be an option to create Cascading attributes between the Types (Objects).
In Windhchill PDMLink their should be an OOTB way to create Cascading attributes within different types (Objects)
For example:
Driven List should work between Change Task and Change Notice objects, currently their is no option do that.
2 Comments
Peridot
Status changed to: New Idea
Ajinkya - would you please describe what use case this is?
Contributor
Hi Jeff,
The Usecase is that customer wanted to have one Single List attribute on Change Notice whose selection will derive the value for Change task Single List attribute, means they want the Cascading attributes derivation between diffrent types, currently I think this is not possible.
Ajinkya
