To be able to manage the Creo material file and share the Creo Material Attribute with an EpmDocument to create automatically a material WTPart and share Attributes between theses objects
1) Need to be able to save from creo a material file to the workspace , to associate it with a SubType of EpmDocument and associate it to a WTPart.
2) Need to be able to designate Material Attribute to share with the EpmDocument.( Conductivity , Resistance etc...)
