The customer wants to be possible to remove the attribute value of EPMDocument in the workspace. CS22920 says "HTML UI Edit attribute action does not allow user to remove attribute. User can remove attribute value in CAD Application." But the user cannot remove attribute value in Creo Elements/Direct Drafting. The customer uses Creo Elements/Direct Drafting.
