Whenever a special characters in used in WPA system while loading BOM (or) IPC etc , then that special character is automatically getting converted to inverted QuestionMark.This issue needs to be resolved in WPA AEAP.
Example :- If symbol "μ" is used in WPA, then it is converted to Inverted Questionmark "¿"
