Undo Revision in Change Task
Bonjour,
when revision is created accidentally or becomes unwanted designer have to remove it from the table, visit object detail page a delete it manually. Would be nice to have a button for "Undo Revision" in change task doing these steps at once:Undo Revision.jpg
2 Comments
Pekholm
Have met similar requirement. Alternative solution is to keep modifications in a isolated area which can be dropped completly or partially without dealing with all dependencies. ProjectLink is working close to a isolated area but you need to do the revise in PDMLink before why you can´t just drop the modifications.
Hope PTC focus to get a solution in the area. Many use cases can be adressed as
- Different change proposals
- Conceptual design scenarios
BR
Per
olivierlp
Community Manager
Status changed to: Archived
