Update particular node rather than exporting/importing entire classification structure
We are doing the modification for few attributes in classification structure, but the complete structure needs to be deleted and imported. So, do we have a way to export a particular node instead of complete structure? This would in turn reduce the overall time taken to update the modifications. Because even after selecting the particular node and exporting, it exports the entire structure.
2 Comments
BrianToussaint
I just went through this back in the first half of the year with a rollout of Parts Classification.  Now I am trying to put in place Documentation Classification and would benefit from just a partial input.  Or even if I wanted to add more to my Parts Classification.  The bummer is that you have to do all the icons over if your reimport.  I don't mind the complete output, but it should have a column to put yes or no to update/create the node.  Also it would be beneficial to have a pointer to the icon for the node.
nsamardzija
