Update the Enumeration for the eMDR H8 section to include "Unknown".
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Solution Architect in a Medical Device company.
2. What version of Windchill are you currently running?
Windchill 11.1 (M020)
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Complying to FDA xml standards, there needs to be an update to eMDR H8 enumeration to include new value "unknown". The internal name needs to comply with HL7 to be successful in downstream publishing. The enumerated value should also be propagated in OOT "View Report" published pdf functionality.
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @MB_10394508 for publishing your idea and welcome to the Community. However, we need more information as specified in the last 2 questions of the form you saw in the submission process. (see below). You may simply add a comment to your idea. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
2. What product & version are you currently running?
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Here are a few examples of well documented ideas:
Windchill alias attributes should be able to map w... - PTC Community
MPMLink - Ability to duplicate (save as) a Process... - PTC Community
Easy way to view Service Effectivity that's been a... - PTC Community
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
achirila
Moderator
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
