Equivalent Link tables is not available on "Related Objects" for object that can have upstream/downstream.
Basically the 2 tables that are available on the Manufacturing Associative Part Structure Browser should also be made visible on the Related Objects Tab of an object that can have upstream/downstream equivalent relation.
