Usage attributes to be copied to children when using "Remove Selected Assembly and move up Child Par
As per current functionality when using "Remove Selected Assembly and move up Child Parts" Assigned Expressions are copied to the Children of the assembly.
This helps in traceability; user will know children belong to which assembly.
Request is to have the same behavior for Usage Attributes for Traceability purposes.
