https://theia-ide.org/
Eclipse Theia is a Web IDE that was written by Eclipse and made compatible with the extensions designed for the incredibly popular VS Code. It is used by GitPod to create dynamic Development environments.
I'd like to see the setup for a dev environment of Windchill include the setup of Eclipse Theia behind an authentication wall using the apache structure that Windchill already has.
This would aid in the evolution of configuration and customization management of Windchill as your customers approach infrastructure-as-code concepts.
