Instead of trying to guess and cater all possible needs of end-users, it would be good to simply give them the choice of the output. For example: the automatic publishing would only create HPGL for viewing purposes and other formats, like PDF or DXF, etc. are created only when end-users request them by manually post-publishing additional files into the representation.
br. Tomi
